Orcrist Posted July 9, 2009 Share Posted July 9, 2009 so i've been making knives since 2003 and i'm now trying to get all the right touch ups. i'm at 1500 grit sandpaper right now, and it gives such a shine a chick could do her hair looking at the thing. i'm looking for paper around 3000 range but i cant seem to buy it at any of the local hardware stores ect. i've heard something about pens and fine sandpaper? and the big question is where can i find colophony rosin. crystalized pine tree sap. i know plain rosin is used for violins ect. but i cant seem to find colophony anywhere. i'm using it for a beeswax/rosin/turpentine farnish on the blade. plz let me know if theres anywhere you can buy it, or possible a better varnish. i'm looking for something really old school though... like a couple hundred years old school :confused: Quote Link to comment Share on other sites More sharing options...
Drewed Posted July 9, 2009 Share Posted July 9, 2009 I googled "colophony rosin for sale" and got:Colophony Pine Rosin andTalasOnline.com - Colophony Rosin Don't know if that helps in BC or not. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted July 9, 2009 Share Posted July 9, 2009 Toothpaste works pretty well for high shine past a certain level of grind - so does a product called Simichrome. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 9, 2009 Share Posted July 9, 2009 Anything after 1600 is *modern*; as my primary focus is pre Y1K we usually go with 1: nothing, 2: Beeswax applied and then heated to soak in and then burnished/buffed 3: one of the drying oils like linseed oil, walnut oil, etc. (note using the old versions maye require extra work to get them to polymerize, sunlight helps!). Now for bone/ivory sifted wood ashes applied with a little water and then shoeshined with a strip of woolen cloth can get you a finish folks will swear is buffed with a powered buffer (Theophilus mentions this in Divers Arts written circa 1120 AD.) Quote Link to comment Share on other sites More sharing options...
