June 27, 200916 yr So if I'm making a knife (something like a buck knife) out of old lawnmower blades, what should I quench it in? Plain water, salt water, or oil... I'm quite confused. Advice would be apreciated.
June 27, 200916 yr I hear there made from mild steel, and sometime tool steels. If you dont know, try a spark test. If its mild water/salt water would probaly work, if its a higher grade probaly oil You need to figure out what it is first. That would be my understanding, someone correct me if im wrong.
June 28, 200916 yr You should have a lot more lawn mower blade than you need. So take several samples and test different procedures. Start with a spark test, that will give you an idea where to start. If played with a couple of lawn mower blades, one was very close to mild steel (I'd guess 1050), one was something that shattered when quenched in water and was red short. ron
