July 5, 200620 yr Someone has said I could use AR wear plate steel to build my fish gigs out of. They said it is used around rock mines in their chutes and such cause it doesn't wear out. Is anybody familier with this type steel or something close? It needs to be 1/4" thick or close and 5" wide and needs to be tempered so that the points don't roll up easy if a rock is hit with it. I have one here I borrowed and will post pics after I get them loaded. Thanx for ya'lls help. Cooter
July 5, 200620 yr AR wear plate is Abrasion Resistant. AR 400 is used around concrete plants ALOT. I have had way too much dealings with that. Sorry, I can't comment on the metallurgy of this material. Only guessing I'd say it has some manganese content.
July 5, 200620 yr Here are the specs for Wearform 400: C - .30 Mn - 1.15/1.60 Cr - .20 Mo - .10 B - .005 BHN 360-400 It is basically an abrasion resistant spring steel.
July 5, 200620 yr Author Heres a couple of pics of the part. Does anybody have any better suggestions as far as type steel to use? Thanx for any help offered, and thanx for past replys. Cooter
July 5, 200620 yr If you have the AR plate, use it; otherwise any flat spring steel wide enough should work well for your application. Avoid the rocks, the moving things in the water are what you're after.
