Steve McCarthy Posted June 9, 2009 Share Posted June 9, 2009 I am making the move from outside and setting up my forge inside. The Hofi blueprint of a side draft looks to be simpler all around. No hole in the roof, less construction, and no rain water in the shop. Will the side draft draw as good as the super sucker. Not that I doubt the word of Hofi, but who else has experience with a side draft set up? Quote Link to comment Share on other sites More sharing options...
peacock Posted June 10, 2009 Share Posted June 10, 2009 I have never use a super sucker but have alot of experience with the side drafts. as long as the flue pipe is at least 10 or 12 inch in diameter they work great. Be sure the tunnel from the forge to the flue slopes a little to the outside so that rain doesn't run inside. I burn a couple of sheets of news print in the tunnel to start the draw. Phil Quote Link to comment Share on other sites More sharing options...
Steve McCarthy Posted June 11, 2009 Author Share Posted June 11, 2009 Thanks for the reply Phil. I am pretty sure I'll go with the tunnel and 12" flue. Where is Hamilton? I'm about an hour from Rola on 63. Quote Link to comment Share on other sites More sharing options...
peacock Posted June 11, 2009 Share Posted June 11, 2009 I am on 36 hiway 45 miles east of St Joe Mo. Quote Link to comment Share on other sites More sharing options...
urnesBeast Posted June 11, 2009 Share Posted June 11, 2009 I had one fabricated to the specs shown in the Hofi print. 15 foot tall stack. The only problem that I had is that once I was not holding my hammer real tight and it got sucked up in the draft. I had to get it out of my neighbors yard... Quote Link to comment Share on other sites More sharing options...
oakwoodironworks Posted June 11, 2009 Share Posted June 11, 2009 I have a friend who has the Hofi draft system and it draws real well. It is the type of system that I plan on putting in my shop for my coal forge. Quote Link to comment Share on other sites More sharing options...
Steve McCarthy Posted June 12, 2009 Author Share Posted June 12, 2009 Thanks for the imput guys. The tunnel draft has a lot of advantages and I'm glad to hear it'll suck hammers. Quote Link to comment Share on other sites More sharing options...
dimenickel Posted June 12, 2009 Share Posted June 12, 2009 just a quick question.. what size thickness on 12" pipe ? 1/8" ?.. and what paint is good to stop the sulphur from eating it away.. - i'm just bout to order my pipe.. finally:D Quote Link to comment Share on other sites More sharing options...
urnesBeast Posted June 12, 2009 Share Posted June 12, 2009 I just got galvi stove pipe. It was thin. Doug Quote Link to comment Share on other sites More sharing options...
divermike Posted June 12, 2009 Share Posted June 12, 2009 I used corrugated 12 drainage pipe, and made my side draft hood out of sheetrock and metal studs, works like a champ, Just shielded the face with some thin sheet metal. It almost got my corgi, but I caught her as she flew by!! (sic) Quote Link to comment Share on other sites More sharing options...
