Side draft or Super Sucker?
I am making the move from outside and setting up my forge inside. The Hofi blueprint of a side draft looks to be simpler all around. No hole in the roof, less construction, and no rain water in the shop. Will the side draft draw as good as the super sucker. Not that I doubt the word of Hofi, but who else has experience with a side draft set up?
I have never use a super sucker but have alot of experience with the side drafts. as long as the flue pipe is at least 10 or 12 inch in diameter they work great. Be sure the tunnel from the forge to the flue slopes a little to the outside so that rain doesn't run inside. I burn a couple of sheets of news print in the tunnel to start the draw.
Phil
