jebb Posted June 7, 2009 Share Posted June 7, 2009 How much gas pressure is needed for a gas forge. I have an oil well on my property but only have 5-8 Psi with a 1" pipe Quote Link to comment Share on other sites More sharing options...
Dodge Posted June 7, 2009 Share Posted June 7, 2009 Natural gas can be used to run a forge but generally needs a burner with a blower at that pressure. Bottled LPG can be run with atmospheric or naturally aspirated burners. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 8, 2009 Share Posted June 8, 2009 You could probably get a naturally aspirated burner to work with that pressure but there's no way to know for sure with unrefined gas. The easiest and surest way is to build a gun burner. A blower supplies the air, the gas pipe supplies the fuel and both are easily controlled. Frosty Quote Link to comment Share on other sites More sharing options...
