TheGreenMan Posted April 12, 2009 Share Posted April 12, 2009 I got a piece of metal about 4x3x1 I am using for an anvil. It is on top of a large trunk but I can not get it fastened in place so it bounces. I know of no where around here to get any large pieces of scrap. I have a chuck of RR track but that is no where near here and would also need to be fastened any way. I tried to use some bent-over screws but that did not work. Any ideas? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 12, 2009 Share Posted April 12, 2009 That's a pretty small piece of steel, barely 3.4 lbs. If steel is that hard to come by I'd call a machine shop and ask to buy a drop or find the largest sledge hammer head I could and use that. Try calling heavy duty truck shops and see if they have a broken or twisted drive axle you can buy or have. Set on end flange up in a bucket of concrete or buried in the ground they make a fine anvil though you'll probably need to flatten the top with a right angle grinder. If you get your piece of rail find a track plate, four RR spikes and spike it to a block of wood. Frosty Quote Link to comment Share on other sites More sharing options...
