it keeps the file from clogging up and leaving large gouges in your work...I use sidewalk chalk from wal mart
Welding suppliers sell chalk for marking steel that is what I prefer. And you need a file card to clean the teeth really often then reapply chalk
So, you can use chalk or soap stone? How often do you clean & reapply? I'm sure it has something to do with how much you are filing, but is there a rule of thumb?
re-apply the chalk after you clean it with a file card ...by the way they make two types of file cards one looks like a flat wire brush the other is a stiff brush on one side the other side is a flat wire brush. the betterof the two is the combo brush
