Nomad
Everything posted by Nomad
  1. Nomad posted a gallery image in Vises
  2. Nomad posted a gallery image in Vises
  3. Thanks all for your input. I need to glob onto some coal still (the Farrier supply 40 miles from the house looks to be the best source at $20 for 50#) to try it out. I will be making a couple cahnges (i.e the angle of my air supply) but I don't think it needs too much. The air supply is variable via the two speeds on the hair dryer. If I need more I'll add a way to block the supply pipe in increments. Thanks, Nomad
  4. RR welcome, I hope you get a chance to revive your forge soon. I'm south of you a bit in Battle Ground (WA) just outside of Vancouver (not Canada) Washington (not D.C). Nathan
  5. I'd appreciate it if you, my very knowledgable friends, would look at the pictures I posted under the gallery,tools,coal forges. I have no experiance with coal (in fact I still need to buy some to try this forge out) and am looking for suggestions. I used what I had or was able to scrounge. (total cost stands at $3 for bolts and $3 for the blower) Thanks, Nomad
  6. Nomad posted a gallery image in Coal, Solid Fuel
  7. Nomad posted a gallery image in Coal, Solid Fuel
  8. Kallsme´n- That looks great! Tyler- Though I wouldn't like to think of the byproducts, it can be done. I think waste fryer oil might be safer but I'm not sure. The following was posted on a metalcasting BB I visit. He used a 20# propane cylinder as the burner and it fire a crucible furnace made of a 55 gallon drum..... http://OpenOSX.com/hotspring/propane-OIL-burner/propane-OIL-burner.html> He also posted this diagram: ''Here is a side "doodle": @ = propane bottle $ = exhaust/flame * = oil _ = intake .. = air ..............@@@@@X@@@@@ .............@.......................................@ $$........@........................................@_______ $$$$$$ $.................................................................... $$$$$$$$$$................................. ________ .............@ $$$$$$$$$$$$$$$$ @ ...............@**********************@ ................@@@@@@@@@@ So, the bigger the pool/surface area of oil - the bigger/hotter the exhaust..." One thing I have found by looking around a bit is that his doodle left out a supply line that drips fuel where I added the X Nomad
  9. AG, welcome to the fray. Small world, I graduated from Arvada Senior High when they were still the Redskins. Nomad
  10. The only thing constructive I can add is make good use of your auto shop time. Glob onto every spring you can as these are temperable and can be reworked down the road, even if you don't have the skills yet. Good luck. Nomad
  11. Hello all, My name is Nathan, I'm pretty good at burning myself, and one of these days I might change the shape of a metalic object! I'm a really amature smith that hasn't lit a forge since I moved a year ago. I decided to surf by the site (it's been longer than a year) and things have changed. It looks great! I've never worked along side another smith and have learned a lot from sites like this one and the people I've met through them (evn'n Jr.) so I wanted to say Thanks to Glen in advance. Nathan Nomad
