Everything posted by SandHuf
Beehive fire?
Thanks, I guess?
Beehive fire?
Lol, I'm just too lazy to search.
Beehive fire?
I think my last question will be should I use anthracite coal or bituminous coal?
Found antique forge
Yup that's what I've got. Yours looks great. I'll be repainting it today, I'll post pictures later.
Beehive fire?
I just need to know how much to buy at a time.
Forges and Fires
This is what I will be using. It's 18" in diameter and about 2-3 inches deep. How much coal would you think?
Beehive fire?
Thanks for the info. Also, how many pounds of coal do you go through in an hour?
Forges and Fires
Could I start the fire with a big blow torch I have?
Beehive fire?
I get what your saying on how to do it. So would the term for the hive shell be clinker? I'm not really sure what a clinker is.
Forges and Fires
How many pounds of coal would say you go through in an hour?
Beehive fire?
Beehive fire?
- Found antique forge
Found antique forge
I probably would put a 1/4" steel plate in. But if you have it like I think you have it, you have it under the air vent so it over laps over the plate. I would do that but I would have to take out the air vent and every bolt on this thing is rusted in and I would hate to have to cut more bolts out. I already had to cut 2 out of the blower hinge.
Found antique forge
So since there is no S it is cast iron. Except since it has no S it doesn't look like the one in your catalog. Mine has 3 legs. I can't seem to find the word clay stamped into the bottom because it is rusted out. Should I do it? I really don't want this thing to crack when I fire it up.
Beehive fire?
I've been reading on techniques for using coal in forges and I read something on a beehive fire style setup. What is this? How do I do it? Do you recommend it?
Found antique forge
So is mine the 145 S, 147, or 146 S?
Found antique forge
I was wondering if the last 2 numbers of 145-18 was the year? That would make it 1918. Is this true?
Found antique forge
Awesome. I can see a few spots of red on my blower so I plan to repaint it that color.
Found antique forge
Thanks for the great info! Can you post a picture of yours?
Found antique forge
It's a bit thin. Will it hold the heat from coke well? Or will it melt?
Found antique forge
Would river clay work ok for claying the pan?
Found antique forge
Heh it's a little late to put the acid on. If it is cast iron, shouldn't I put clay in it to keep it from cracking? I'm a bit new to blacksmithing so excuse my ignorance please. Also should I bother painting it?
Found antique forge
What are the steps to claying the pan? Would I use fire clay? Are there certain ingredients to mix with the clay?
Found antique forge
So I found this old coal forge. It had no name on it, just the numbers 145-18. I looked into it and I think it's a champion forge. It's pretty rusted up, so I put some rust dissolver on it. My questions are; what type of metal is it made of? It is safe to use? Should I try claying the dish if it is cast iron? The blower works and I would really like to use it.
