I got my forge built. Had some 1/8" steel plate laying around and made this forge before I started on my 5 gal propane tank forge. Interior measurements are 4 1/2" wide x 9" deep x 3 3/4" high. It has 3" 2300 degree ceramic blanket on top and bottom, with 2" insulation on sides.
Front is open, back has size same opening as the front, but a steel door with 1" ceramic board coated with satanite closed.
Got 1/4" satanite on interior, and when I get the burner running right, bring up to temp to final cure before coating with Metrikote IR.
Problem is that I have a Goede 130,000 BTU burner, with the 30# reg. The mig tip orifice appears to be an .021, and it only likes rel high pressure and
don't burn right for beans. I changed to a .023 and it works better, but in the forge the flame huffs at times with 5-8 lbs pressure. I tried an .030 mig tip and it works better
outside the forge. I will try it in the forge tomorrow and see if it is any better. Is lower pressure better in this 162 cu inch forge?
Am I over thinking this, or should I get a z burner.
I'll post some pics tomorrow.
By the way I read just about every burner 101 and researched so much I can't make up my mind.
