saintjohnbarleycorn Posted February 5, 2009 Share Posted February 5, 2009 I have heard the term, "hand burner" what would you use that for exactly? TO heat something you are carving or build a temporary forge? thanks kevin Quote Link to comment Share on other sites More sharing options...
PeterDE4 Posted February 5, 2009 Share Posted February 5, 2009 I think that it would mostly be used for pre-heating metal prior to welding. I usually use a rosette head on my oxy/acetelyne torch, but I could also pull a burner out of a forge and use it as a hand held torch. I'm sure that there are other uses, but that's the first that comes to my mind. Pete Quote Link to comment Share on other sites More sharing options...
Marc Posted February 5, 2009 Share Posted February 5, 2009 Some I know use a big weed burner or roofing torch to pre-heat. Quote Link to comment Share on other sites More sharing options...
highlander Posted February 6, 2009 Share Posted February 6, 2009 I think that it would mostly be used for pre-heating metal prior to welding. I usually use a rosette head on my oxy/acetelyne torch, but I could also pull a burner out of a forge and use it as a hand held torch. I'm sure that there are other uses, but that's the first that comes to my mind. Pete Hello, fellow Delawarean! Quote Link to comment Share on other sites More sharing options...
