eawols01 Posted November 20, 2008 Share Posted November 20, 2008 I am attempting to construct a tire hammer. In browsing the internet at other builders' versions, I have noticed that some are using a thick solid metal drive wheel attached to the motor's shaft as the clutch. What do you all generally use for this? Did you turn it out on a lathe? Can it be purchased somewhere? What are your solutions for this? Thanks! Quote Link to comment Share on other sites More sharing options...
markh Posted November 20, 2008 Share Posted November 20, 2008 John Wayne Taylor Phone: 334-514-2254 Location: Wetumpka Alabama This guy is a friend of Clay Spencer and he makes and sells a lot Tire Hammer components to Clay's specs. He gave me the prices and they seem very reasonable. the drive wheel is $40, the spring is $30, the arms are about $140, and the lead weight is around $7. I plan to buy these from him because he uses the same jigs as Clay Spencer so I know the parts will be better than my own products. Quote Link to comment Share on other sites More sharing options...
