August 25, 200817 yr I am new to propane forges..I use propane on one of my torch set ups but Ive always used a coal forge..Im looking at buying a propane forge and am wanting suggestions on a two models... A..Small possibly one burner for everyday forging(no welding) B..A good two burner that will get up too welding temp.. The reason Im asking on two models is that I havent decided on whether to buy a small forge for everyday normal forging and use my coal forge for welding or to buy a propane forge that will do both...Price is of course somewhat of a concern..Thanks
August 25, 200817 yr A bigger forge will (of course) use more gas even when you're not welding. If you can get away with a one-burner for for most of the stuff you do, I'd go that way. I can weld in my home-made forge with one Reil-style burner, but if I had a coal forge handy, I'd likely use that for welding to save my gas forge lining.
August 26, 200817 yr Oh, I forgot, the MAD smiths use a one burner and they can weld with it. SO the one works, and the two is just bigger and a little bit hotter. :)
