August 18, 200817 yr Does anyone have any good pics of peter wright vises(not much on the web about them)? Did they make a 3.5 inch one? Sean
August 19, 200817 yr I have 3 at home. I'll try to post some pics for you later this afternoon. they all have similar markings but a wide range of sizes. Later, Gary
August 21, 200817 yr Sorry it's taking so long. I haven't been able to get my pictures to upload. Glenn's helping out and they should be in the gallery soon. The first shows the main body and what I call the chamfered uprights. The second shows what I've found to be the normal mounting bracket for most PW vises that have them. Two of mine have these brackets. The third shows where they are marked on the bell housing. Peter Wright, Solid Wrought. Some are stamped on the top of the jaws, although are usualy too beat up to make out much. Hope this helps. Pics under Peter Wright, vise, leg vise. The reason the photos would not upload for you was the HUGE size. Reduce the size to 1024 max long or tall and it should work.
