My no-weld 2x72 belt grinder
Not that I can't weld - I just didn't feel like it. I used 18 and 12 inch pieces of Unistrut and 3/8" and 1/2" nuts & bolts with the right angle brackets and plates.
I did cheat and tack in an 8-32 nut for the tracking adjuster. I was going to epoxy a 1/4-20 t-nut into the hole but I ran out of epoxy and the 8-32 gives a finer adjustment.
Motor is a 3/4 horse washing machine motor. 2 speeds - 1140 and 1750 rpm. With a 6" drive wheel I calculated the belt speed at about 2200 fpm on low, 3400 on high.
Spring is from the same washing machine.
For the jackshaft I drilled out a couple of the angle brackets and put 3/4" OD 1/2" ID bushings in them. Turned the drive wheel myself. The others are 3" longboard wheels with abec 9 bearings on M8 bolts.
Total out-of-pocket cost was about $40 for the switches and wheels - had everything else laying around from other projects.
I still need to enclose the motor better. The little crate is just a frame to hang some filter material on. Eventually I'll make a platen, too.
Thanks for looking - Jim
