Joe E Posted November 22, 2019 Share Posted November 22, 2019 Greetings everyone! I am in the process of putting together a ribbon burner forge and I was wondering if any of you would be so kind as to share how you ran the gas to the air pipe to feed propane in. I am planning on using 2” black iron pipe and I have a 2x 3/4” tee for the propane inlet but need some pointers on where to go from here. What size and type of fittings do i need? Is a gauge necessary? Any help would be appreciated! Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Joe E Posted January 23, 2020 Author Share Posted January 23, 2020 I got it figured out y’all. Not sure if it’s standard but it works. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 23, 2020 Share Posted January 23, 2020 Looks good to me, although I don't use a forced air burner. You figured out how to control the propane and air it should work fine. Quote Link to comment Share on other sites More sharing options...
