clifford Posted April 4, 2008 Share Posted April 4, 2008 Does anyone use this steel? Why isn't it used more often? I have used 'W1' and really don't like it. Seem like it doesn't really soften ( is that the right terminology?) when heated. Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted April 4, 2008 Share Posted April 4, 2008 A2 is an air hardening steel. Lotsa problems tryin gto forge it. For stock removal it makes a great blade. Quote Link to comment Share on other sites More sharing options...
Don A Posted April 4, 2008 Share Posted April 4, 2008 W1 is what a lot of files are made from (others are 1095). I use a lot of old files, and I think it moves well when it's in the proper forging range. Remember, this is a really high carbon steel, so it is going to have a tight forging range. Heat to non-magnetic (critical) and work down to a red heat, then back in the forge. You can't push it like it's mild steel. Like Bruce said... I'd stay away from the A's and M's and other complex steels, particularly the air-hardening stuff. I have never used it, but I've heard good things about O-1. It is a readily available oil hardening steel. Don Quote Link to comment Share on other sites More sharing options...
MooseRidge Posted April 4, 2008 Share Posted April 4, 2008 I've used A2/S7/O1/h13 for chisels, gouges, and such. They're harder to work but handle the impact and heat stress of making wizards and animal heads, chasing, and other applications. As knivemaking requires much more refinement over the entire piece (instead of just the ends), I would not recommend using them for knives... I am including a link to a link with suggested uses for different tool steels....http://www.pvsteel.com/docs/Tsb-093.pdf Chuck Quote Link to comment Share on other sites More sharing options...
