don schad Posted June 2, 2016 Share Posted June 2, 2016 Hi all, I am considering purchasing an older Anyang 165 two-piece hammer. At present the age of the machine is not known, but it is at least 20+ years old. I have read about some of the older machines having a problem where they get very hot. I don't know if this is a problem which can be fixed or not. But I am also wondering if there are other problems or if people have thoughts on these older machines. Are they comparable to the current crop in terms of reliability and quality? I am also considering purchasing a new 88, but this other machine just came up. Is the control on these older 165s less then on the current 88s? I would love to hear any experiences or thoughts. Thanks for your thoughts, Don Quote Link to comment Share on other sites More sharing options...
ironwolfforgeca Posted June 2, 2016 Share Posted June 2, 2016 witch hammer depends on what you're forging ? a new 88 gota to be around 10 G ?? a used 165 ? $$ - is it a one piece or 2 piece ? A two piece is a bit more work to install myself I am a more power guy can you test run the 165 ?? or get near a 88 ? I have never heard of the heat problem you talk of unless its run Hard all day & then some all hammers get warm / hot depending on use a hard day on my 33 & you can't hold you're hand on it and yes I push the 33 when needed ! I need the 65# up & running Quote Link to comment Share on other sites More sharing options...
don schad Posted June 3, 2016 Author Share Posted June 3, 2016 I've moved away from this machine I think. It isn't 100% clear who the manufacture is, and I don't think I want to get into a project if things go bad. Thanks though. Quote Link to comment Share on other sites More sharing options...
