Rberry1911 Posted April 10, 2016 Share Posted April 10, 2016 I recently noticed my regulator leaking from the back screw i took it off and replaced the o-ring and stopped the leaked but now when i turn on the gas the needle on the pressure gauge spins all the way around.... Just wondering what could be causing this? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 10, 2016 Share Posted April 10, 2016 26 minutes ago, Rberry1911 said: I recently noticed my regulator leaking from the back screw i took it off and replaced the o-ring and stopped the leaked but now when i turn on the gas the needle on the pressure gauge spins all the way around.... Just wondering what could be causing this? Take it off the tank and replace it. It's worn out is what's causing it. This IS a propane regulator and not an acet regulator on a propane tank yes? If it's not rated for propane it's a serious fire hazard take it off soonest. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Rberry1911 Posted April 10, 2016 Author Share Posted April 10, 2016 Nahh its just hooked up to a 20lb tank it came with my forge. Its about 4 years old. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 10, 2016 Share Posted April 10, 2016 It's worn out, replace it. You could take it to the shop and have it repaired but buying a new one is cheaper, faster and you'll have a new regulator. For a few bucks it just isn't worth trying to fix the things. If it leaks it's failed, DEAD. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Rberry1911 Posted April 10, 2016 Author Share Posted April 10, 2016 Alrighty thanks Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 10, 2016 Share Posted April 10, 2016 44 minutes ago, Rberry1911 said: Alrighty thanks You're welcome. Propane problems are good things to ask about, the stuff can be dangerous. I don't have so many friends I can afford to lose one if I can help it. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charlotte Posted April 10, 2016 Share Posted April 10, 2016 Basic pressure of liquid propane is 256 lbs sq inch. Not to be played with. When gauges do what you described Shut off gas and pray nothing else fails!! When regulators fail they need to be replaced. Quote Link to comment Share on other sites More sharing options...
