November 25, 201510 yr I've known the folks at the local steel supply for many years. I never buy in large quantity but I do buy frequently. And they give me their deepest discount....?cause they like me or because they like donuts ?". I mention that the flat dies in my hydraulic press are mild steel and they deform rather quickly. Sitting at his desk, he tells me to go to the first building, third rack, far end on the bottom is a 2 X 3 foot piece of A/R plate. Next to it is 30" of 2 1/4" round bar, Blanchard ground used for hydraulic piston shafts. You can have that too if I want it (cause it has some surface rust.) Amassing memory, because I can't remember what I had for lunch let alone where a certain piece of steel is in this huge warehouse. So if I cap the flat dies with the A/R, Can I mig weld it without effecting it? .....................
November 25, 201510 yr Here's what looks like a good write up on welding AR to dissimilar metals http://www.thefabricator.com/article/consumables/cracking-the-case Pre-heat, slow cool, low hydrogen. The write up lists some specific mig wires to use.
November 26, 201510 yr Author Thanks for the link...I know that I tend to over think/over engineer things.....Just ask my wife...no that's not a good idea. One of the greatest resources is the folks on this forum who help out with info/ideas/resources.....Keith
