November 15, 201510 yr I have the knife making bug this week and here's my second blade. It is made from a farriers rasp labeled patented save edge USA which I am not sure if that's the company or not. This is straight out of the forge so I have to grind it up a bit still and heat treat. I am gonna make a guard plate which I totally forget the name of what they are called and the handle will be made from a piece of antler. Here it is:
November 15, 201510 yr Looking good, I would clip the tip down to have a bit of a flat to make it a good skinner. Similar to this one but just enough to allow raising the tip when skinning.
November 16, 201510 yr Author Do you guys think the tang is too small? Thanks I think I will leave this one and make another one a skinner. I think it looks pretty cool like this as a show piece or conversation piece.
November 16, 201510 yr If you want to have a longer tang you could work down some of the ricasso (either hot or cold; but you get more length doing it hot!)
November 16, 201510 yr Author hmmm... I plan on using a piece of antler as the handle. I suppose I will redo the tang and make it a bit larger next time im at the forge. Do you guys think that the bowie shape is fine or should I fix that too? Oh yeah sorry I put the title as tanto where it is actually a bowie.
