ChadBasan Posted September 26, 2015 Share Posted September 26, 2015 I just bought this anvil for 150. I have not seen any anvils with a base like this. I was wondering if it was rebuilt or came like this. The markings I can find say .Trenton. Solid Steel Wrought. And U.S.A. there is also a 1 on the bottom. Any help would be great. Quote Link to comment Share on other sites More sharing options...
Frozenforge Posted September 27, 2015 Share Posted September 27, 2015 You have the upper half of a Trenton that I would guess started out as about 150lb. The original factory weld between the top and bottom failed at some point fairly early in its life and it was then attached to the plate. Nothing wrong with it the way it is so make a stand for it and put it to use! Quote Link to comment Share on other sites More sharing options...
