LibrariaNPC Posted September 14, 2015 Share Posted September 14, 2015 In early August, I took a pattern-welded steel class with James Viste at Peter's Valley. I made this knife, shaped these two "coins," and left with another billet that (should) work.Metals were jackhammer bits, mill saw blades, and mild steel. Random pattern, 96 layers, differential heat treatment for the blade with an oxyacetylene torch and canola oil.Sanded to 1200 grit by hand and soaked in home-made ferric chloride for 30 minutes. Lightly sanded again with 1000 grit sandpaper. Haven't decided on a handle yet; wanted to see how the pattern turned out before committing to a material. Debating between clear epoxy, finding some wood without breaking the bank, or just some grey paracord as a temporary fix so I can at least use it.I've included some WIP shots as well for your enjoyment.As always, I'd appreciate any input! Quote Link to comment Share on other sites More sharing options...
