March 29, 201511 yr Thought I would share my DYS 2x72. 2x72 scrap grinder.: https://youtu.be/pjqzM5yGMWI.Table saw turned belt grinder.: https://youtu.be/xWobnS-f48k .Table saw 2x72 belt grinder belt tension.: https://youtu.be/lkRZBqZVxcg
April 4, 201511 yr Nice job on the belt grinder Damion78. That is on my short list of things to build they are way to expensive to buy new.I also have been thinking about using automotive idler pulley's / wheels. Steve,
April 7, 201511 yr Author Thank you it has been a fun project. I started with a 1/2 hp motor, moved up to 1hp both bogged down. I am now in the process of fitting a 6000 rpm 9in angle grinder motor to it. I have had it hooked up but need to step pulley it down it's a little to much but it really takes the metal off and shows no signs of bogging down at all. I'll likely do another video when I'm through.
April 7, 201511 yr Excellent build. Makes me want to get a new table saw so I'll have an old one just laying around
