March 8, 201412 yr Hi, I recently purchased a fly press. It is quite a bit different than the presses commonly seen in these parts . Not sure if i have attached these correctly. Comments welcom. ErnieD
March 8, 201412 yr It's a die tryout press. When setting up stamping dies or molds, the toolmaker can bolt it into the press and check alignment or shutoffs without putting it into a production machine. I'm sure you can adapt it to blacksmithing.
March 8, 201412 yr Author It has a 3 start thread so I think you are right, it can be adapted for blacksmithing. I think it is 50-60 ton machine. Ernie
