ironsmith Posted June 18, 2013 Share Posted June 18, 2013 hey guys, goofed off at work today during my breaks and made this, 26" tall 19" long 4" wide. schedule 80 pipe legs. 1/2" plate feet and under mount for anvil anvil is fork lift blade :) 1 1/4 or so thick Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted June 19, 2013 Share Posted June 19, 2013 looks good you will want a hardie hole. it comes in real handy Quote Link to comment Share on other sites More sharing options...
ironsmith Posted June 19, 2013 Author Share Posted June 19, 2013 yeah, they do for sure. like I said just foolin around at work! :) next time i have the iniitiative to make on, i will prolly drill and drift a hardy in just to say i did :D . Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted June 19, 2013 Share Posted June 19, 2013 You need some support in the center. I bet it's gonna bounce under heavy use. :o Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted June 19, 2013 Share Posted June 19, 2013 4 inches wide may prove to be a tad bit narrow. Problem is easy to solve by adding strips to both long sides. Of course vee groove the edges and properly weld. BTW I would have installed my hardy prior to laminating to bottom piece. Consider adding some braces between the leg bottoms to help reduce springing. Enjoy! CARRY ON Quote Link to comment Share on other sites More sharing options...
