June 2, 201016 yr Well Ive searched far and wide and I still havent found it. I dont know how to start a charcoal forge fire. I would assume that it would be the same as coal? I got a big piece of my charcoal and tried to light it and it wouldnt light without lighter fluid. I know you arent supposed to use lighter fluid for coal, but does that hold true for charcoal? You can go Flint and striker on Char cloth-wood shavings-twigs-blow the ember into the charcoal but it takes about 2 minutes. A propane "weed killer/ice melter" torch takes about 10 seconds to light your charcoal. I use both. BUT as others have mentioned, keep those buckets of charcoal close, you'll use a lot!! But it's fun!!
June 13, 201016 yr i had a burner, till the grommet killed it....news paper works fine..3 bits crumpled, light, slow air, pour charcoal on top...and your away...i do this once or twice a day.
