Az Handrail Code ?
Good morning Arazona smiths,
What code are yall using for handrails, and is available on line?
After living with the rail I made them 9 yrs ago here in Alabama some old customers are wanting one for their new home in Az. It'll be level with with 1 step down.
Thanks guys,
Kevin
Arizona the codes are dictated by county building code and can be found on line for each county. 36" high top rail and no vertical spaces larger than 4" or below the bottom rail is pretty standard. Some counties will allow a cable railing and some won't.
Thanks Harold,
We're mostly irc 2009 here in Al. With a little 2006 in historically minded areas.
