March 30, 201313 yr Hello all, iv been having a problem drifting a spike to fit a handle. I start off with a drift made out out 5/8 sucker rod, but when it starts to open up to around the 5/8 mark the metal on the outside of the eye always splits or cracks. I tried it 3 times last night with the same result. Anybody have any suggestions?
March 30, 201313 yr Yeah try a slitter first. Then take your drift and enlarge the hole. If your metal is splitting you're working it to cold. I did some spikes and had cracks. the hotter the better with spikes. Take Care TJ Smith
March 30, 201313 yr In the tools section a while back Brian Brazeal did a thread on slitters and drift and the geometry involved,,see if youi can find it,,good stuff!
March 30, 201313 yr Author Thanks guys, I guess ill make one and give it a try.How wide should the slitter be do you think?
