February 22, 201313 yr This parang was a commission from a customer who wanted something similar to the previous parang I posted, but gave me a free hand if I wanted to try something new. This is the result, one with more of a point to it. The steel is 5160, triple normalized, triple hardened, and triple tempered. The integral socket handle is wrapped in olive drab paracord with coyote brown two-strand Turk's head knots, impregnated with Minwax Wood Hardener. The blade length is 14 1/2" and the overall length is 20 7/8". It shaves hair of course. :) The customer wanted a lanyard, somthing I've never added to a bush sword before. With the integral socket handle, it was fairly simple to do, though. I tied a length of paracord in the center around the choil, ran the ends through the hollow of the handle and out the back, then tied it off. I really like this design. I think I'll do something else with it. :D
February 23, 201313 yr That looks really good. How does triple hardening work? Do you heat it up to non-magnetic and quench it in oil three times?
February 23, 201313 yr Author Homeshow - Don't know what to tell you; the pics show up fine for me. ??? :( Andrewwillis - Thanks! After stock removal, I heat and quench, heat again and quench, then heat again and quench. Then temper. Not all steels benefit from that, but 5160 does. I single quench 1084 and 4140.
