MLMartin Posted January 12, 2013 Share Posted January 12, 2013 I have been looking for a recommended belt speed for these belts. I have the coarse version. I will typicality be running heavy coarse belts on my 2 by 72 belt grinder, 24g 36g 60g. With the heavy grits I would normally run my grinder around 5400 F/M. With this in mind I plan on using a 6inch drive wheel on my 3450rpm motor. But will the non woven bear tex belts survive this speed? Or do I need to use a 5inch drive wheel and have a 4500 F/M? Thanks for the help. I have used 2 by 72 grinders many times but have never built one so I am unsure of the specific speeds I should run. Mackenzie Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted January 12, 2013 Share Posted January 12, 2013 Wot does the maker call for? I use a variable speed grinder and almost always find that different belts, even of same make and brand seem to cut better and or smoother at different speeds. Quote Link to comment Share on other sites More sharing options...
MLMartin Posted January 12, 2013 Author Share Posted January 12, 2013 I searched all over the Norton site and could not find a recommendation, I guess I will need to call customer service. A variable speed would be great but a little out of the price range at the time. Quote Link to comment Share on other sites More sharing options...
