Frank Turley Posted December 5, 2012 Share Posted December 5, 2012 I just wanted to mention that I've been using a Makita hand held sander for a number of years, and I like it. It takes a 1 1/8" x 21" belt. When I show it to others, they are sometimes surprised that there is such a thing. I think the sanders are currently sold with a variable speed adjustment and are in the range of $240-$250 retail. They also make one with a 3/8" wide belt. There is also the "high priced spread" made by Dynabrade. They have abrasives so narrow, that one of their sanders is called a Dynafile. This was brought to mind recently, because after several years of service, I had to replace the smaller of the two pulleys and the so called "shoe" (platten). Surprise! The old pulley had a little capsulated race of needle bearings inside with a press fit. Not being a machinist, I split two sides of the hollow cylinder with a little zip saw just shy of the bearings. I was able to split the steel pulley in two. I inserted the bearings in the new pulley with slow, steady vise pressure. Quote Link to comment Share on other sites More sharing options...
clinton Posted December 5, 2012 Share Posted December 5, 2012 Those are great little sanders, I sanded down the side of my house with one and it is still going strong. It is a variable speed sander, I have Ship Lap siding in a pattern called "Teardrop" that has about a 2 1/2 inch profile with a rounded nose at the bottom edge. The siding is redwood (house built in 1943). I had to scrape and sand to bare wood to get a good coat of paint. There is a wide range of belt grit available also Quote Link to comment Share on other sites More sharing options...
