first forge build
so here is my first forge i ever made after I failed to make a reil burner correctly just needs some kawool and itc and should be good to go thanks everyone for the newbie help
post-29101-0-69347300-1354393774_thumb.j
Looks good! I am currently building my first gas forge at a slow pace. I've built a couple of foundry furnaces/ vertical forges using homemade refractory and a Harbor Freight weed burner which worked pretty well but they were both really inefficient with fuel and retaining heat.
Looks to be a serious piece of business. How does it work? The tubes on the burners look a little long in the picture. Are they 8:1, if not what is the ratio?
