EricS Posted November 10, 2012 Share Posted November 10, 2012 i got to get in about 3 hrs in at the forge today. being the rookie i am i decided to try some forge welding and practice being consistent and improving as i made the same object over and over. first i spent about an hour making the same drive hook. the first one took about 15 min and the last one about 8 min with considerable improvement in relative quality. next i took on some forge welding in the form of a fire poker. welded a loop on the working end cut it formed the points. next i welded 5- 1/4"rounds together at both ends(should have used 4) then welded attempted basket handle to poker. the poker need to be straightend and cleaned up. the info you guys have put on here about forge welding technique has made it pretty easy to weld if you follow the steps every time, thanks. Quote Link to comment Share on other sites More sharing options...
ramsies11 Posted November 10, 2012 Share Posted November 10, 2012 NICE! you have done some beautiful work! Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted November 10, 2012 Share Posted November 10, 2012 Looks like you had a good productive 3 hrs. Well done. Quote Link to comment Share on other sites More sharing options...
