Jim-the-Jedi Posted July 6, 2012 Share Posted July 6, 2012 Hi, I'm trying to find a steel supplier in the uk that can provide me with 2 suitable steels to make Damascus with. Can anyone point me in the right direction for a supplier (and make any suggestions as to what would be good steels to use) I hopefully have some O1 on its way to me any suggestions as to what would be good to pair it with? Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted July 6, 2012 Share Posted July 6, 2012 When you choose steels to weld together you need to make sure they are heat treated as near to the same as possible. )-1 is not one I use in pattern welding. A favorite pair I use is 1084 and 15 N 20,, They will weld for anyone that can weld. The contrast is wonderful. one heat treat works for each of them. i cannot translate those names to the UK equivalent but expect google can..I also expect someone from your area will jump in and ,provide supplier information. Quote Link to comment Share on other sites More sharing options...
Dave Budd Posted July 7, 2012 Share Posted July 7, 2012 the easiest and best place to get steels for pattern welding in the UK is from Mick Maxen. He buys in C20 (i think) and 15N20 from sweden and cuts them up for welding. The 15N20 is the tough one to get in the UK and if you get it direct from Sweden you have to buy tonnes of it, literally. Quote Link to comment Share on other sites More sharing options...
Jim-the-Jedi Posted July 7, 2012 Author Share Posted July 7, 2012 Thanks for the replies, Dave - have been in touch with mick and sourced some 15n20, found someone to supply high carbon stuff from another thread you'd suggest a supplier on. Thanks again, just got to wait for some deliveries then time to get busy :) Quote Link to comment Share on other sites More sharing options...
HDF49 Posted July 7, 2012 Share Posted July 7, 2012 I found this site a while ago http://www.patternweldingsteels.co.uk/ but I have never ordered from him. EDIT: Ah looks like you found some, beaten by a minute! Quote Link to comment Share on other sites More sharing options...
