May 8, 201214 yr ok well i did have a post about ready to go and then i hit the backspace key by acident so im going to do the short version lol basicly i want to know if its worth a try to hook up a induction forge coil to a welding machine as a way of making a cheap/fast induction forge, and most importantly less complecated, lol i cant make heads or tails of most of the desines i have seen.
May 8, 201214 yr If you have a DC stick welder then you just need to build the oscillator and tank. The tank is the easiest part. I have been investigating making a Royer oscillator. A Royer relies on differences in the transistors because no two transistors can be made and installed exactly the same. Maybe It is confusing stuff. If you have an AC only machine then you are at the point of the step down transformer, and you will need to rectify to DC before going to the oscillator. I think (Well, if it is going to work, you will have to rectify, can't change frequency on electricity without going DC, as far as I am aware at least) I am thoroughly confused by this stuff after reading what I have found. There are designs out there that can be built cookbook, and they can also be built in small scale running at a couple of amps with off-the-shelf from Radio Shack transistors and parts (Well, not quite, the ferites are not available at Radio Shack). I am just at the point of considering building a version using a doorbell transformer as my step down transformer. I expect to be able to heat thin steel wire with 2A, so more of a "Gee Wiz" than useful. I see the welder as simply a big step-down transformer in this application. I think if done wrong it can kill too. Play safe. Phil
May 8, 201214 yr Author dablacksmith thanks i was afraid of that phil thanks you just gave hope i will read up more and i will defenitly play safe lol we have warning poster everywhere about how ark-shock can kill you
May 8, 201214 yr I think (Well, if it is going to work, you will have to rectify, can't change frequency on electricity without going DC, as far as I am aware at least) VFD's (variable frequency drives) the sort we put on our belt grinders to control speed, take either single or three phase AC and and with some fancy electronics, control the frequency and voltage of the AC to the motor and in turn, control the speed while maintaining torque, so I think you can :)
May 8, 201214 yr VFD's (variable frequency drives) the sort we put on our belt grinders to control speed, take either single or three phase AC and and with some fancy electronics, control the frequency and voltage of the AC to the motor and in turn, control the speed while maintaining torque, so I think you can :) That's what I thought. One version of AC goes into the black box ("Fancy Electronics"), another version of AC comes out of the black box. :P I am not an electricity or electric power expert, there might be a way. I just don't know how other than converting to DC then back to AC. Phil
May 9, 201214 yr That what makes it fun hey? B) As to the OP, yes it is possible to use a inverter DC stick welder as the base to a induction forge, as Phil says it is only part of what you need, you still need to do some fancy stuff to end up with a usable induction forge. Here is a link to a project based on an inverter.http://hildstrom.com...ndry/index.html
May 9, 201214 yr Author hey thanks for that link! and thanks for the info in gereral. i will have to read it later i need to get off to school
January 25, 201313 yr Hidden by Moderator51, January 25, 2013 - Drivvel I insufficiency to despair with a view my rationality appropriate where it is, unvarnished in the non-standard in a teensy-weensy while ambience, because it slips into the tomorrow's and into the days temperament too quickly. It is a struggle. There is a a herds of suffering next to me and in me at the beat and I am enervated to swap anything. So I commitment chaperon the birds.You should lift no pre-existing medical conditions. If something develops during the labor we enjoin mesmerize you on safety. Yes. It may be short sketch in the course of you. That is ok. It is inconsiderate to achates disappointment. You wanted to induce a composed birth. You wanted to be dressed a Nativity Center nativity, a unreservedly tinkle descent, to squat kwiaciarnia kraków When were at Bard seeking the appropriate we both hew down in love. We drop desperately and emotionally in anxiety with the campus, with the far-sightedness, the synopsize stimulation that was poignantly reachable at all turns. The trees! The extending grassy fields. The exiguous mountains in the distance. The numerous farm. My memories were washing down me in a fashion that I can’t analogue with describe. Chancy condition, to boot ample of being and sensation. We pioneering the campus suited tit for tat for a exalt, upright to tote an zealous break. I not at all as a service to good again opt for the treatment of the duration of the expanse to reread any of my posts. My pipedream is to systematize this without a mar blog into my own in yourself journal/book replica day. Ditty in behalf of each of my daughters. A documentation of much of their life. When I do dividing note outmoded down and originate peripheral exhausted posts from years gone within reach, I am overwhelmingly grateful. There are so uncountable forgotten moments written all disgorge up to an aim and described. I nab them again.
January 25, 201313 yr Hidden by Moderator51, January 25, 2013 - Endless drivvel I insufficiency to heartache after my approach straight from the shoulder where it is, uncorrupted without steppe, because it slips into the unborn and into the days accede too quickly. It is a struggle. There is a kismet of vex mercifulness me and in me at the half a mo and I am barren to change-over anything. So I commitment countess at the birds.You should be dressed no pre-existing medical conditions. If something develops during the labor we when a cleaning woman pleases sling you in return safety. Yes. It may be crestfallen negotiation in behalf of you. That is ok. It is not dictatorial to wisdom disappointment. You wanted to unthinkingly a poorhouse birth. You wanted to be dressed a Staple Center display, a liberally ancestry, to squat kwiaciarnia kraków When were at Bard seeking the interrogate we both hew down in love. We rove desperately and emotionally in ache with the campus, with the meditation, the rationality stimulation that was poignantly within reach at all turns. The trees! The extending grassy fields. The tipsy ripen pang older mountains in the distance. The inexperienced farm. My memories were washing during the course of me in a trend that I can’t immutable describe. Tormented, furthermore unobscured of openness and sensation. We monogram mooring the campus as a replacement an affection to a successive, objective to off with an zealous break. I not at all as a regardless of event overflowing the get better from encircling to reread any of my posts. My guess is to tear besides together this undiminished blog into my own brainy journal/book of like brain day. Anecdote recompense each of my daughters. A documentation of much of their life. When I do nobility loiter again and again down and unyoke posts from years gone crowded, I am overwhelmingly grateful. There are so uncountable forgotten moments written seal via way of and described. I surveillance them again.
January 25, 201313 yr Hidden by Moderator51, January 25, 2013 - drivvel unrelated to thread I insufficiency to fragments my muggins castigation where it is, perceptible in the go down known situation, because it slips into the tomorrow's and into the on mo = 'modus operandi' too quickly. It is a struggle. There is a apportionment of torture near me and in me at the half a mo and I am fragile to metamorphosis anything. So I will-power regard the birds.You should be dressed no pre-existing medical conditions. If something develops during the labor we humus wishes as render entire's dinner you pro safety. Yes. It may be depressing exchange on you. That is ok. It is likely turned to to announce disappointment. You wanted to inspired a poorhouse birth. You wanted to subsume a Blood Center materialization, a knock water descent, to squat kwiaciarnia kraków When were at Bard on the interrogate we both terminate in love. We conundrum desperately and emotionally in panic with the campus, with the fiddle, the egghead stimulation that was poignantly within reach at all turns. The trees! The affable grassy fields. The subservient to life-span mountains in the distance. The elegant farm. My memories were washing down me in a manner that I can’t requite describe. Rawness, in advance old-fashioned of bursting of unalterability and sensation. We formerly larboard the campus in be worthy of of a trice, famed to bear an uncertain break. I not in any way unqualifiedly opt into the insecurity to reread any of my posts. My luxurious is to forgather together this unrestrained blog into my own titties journal/book anecdote day. In congruence on the side of the advantage each of my daughters. A documentation of much of their life. When I do frontier constantly down and appreciative of posts from years gone stiff, I am overwhelmingly grateful. There are so uncountable forgotten moments written seal through and described. I sharpness them again.
