a62rambler Posted April 12, 2012 Share Posted April 12, 2012 I bought a Champion No. 4 blower. It is powered by a belt. I am curious as to what ratio I should have between my turning pulley and the one on the blower. I'm guessing 10 to 1 so that one turn of the crank gets 10 turns of the blower. Can anyone tell me if that is correct based on other champion blowers? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted April 12, 2012 Share Posted April 12, 2012 That blower is probably meant to be powered by a motor. 50:1 is a typical ratio for hand powered. Phil Quote Link to comment Share on other sites More sharing options...
a62rambler Posted April 12, 2012 Author Share Posted April 12, 2012 Thanks, I was way off then. Next question. Does it matter which way the blower is turned? Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted April 12, 2012 Share Posted April 12, 2012 On some models it does, some it doesn't. Try to get a feel for it. If it blows air both ways, then you're set. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted April 13, 2012 Share Posted April 13, 2012 If the outlet is centered in relation to the axle and inlet, it should turn either way. The unidirectional types have the outlet offset to one side. Quote Link to comment Share on other sites More sharing options...
a62rambler Posted April 13, 2012 Author Share Posted April 13, 2012 Thanks HW, that answers my question. So obvious I should have figured that out just looking at the various blowers. Quote Link to comment Share on other sites More sharing options...
