ChrisWard Posted January 30, 2012 Posted January 30, 2012 I have started building a venturi forge and am unable to get enough pressure. I have seen that others have 2 1/2 PSi to their system. I have a brand new propane tank, pressure regulator. I come out of the tank into a new regulator down to a 3/8 inch ball valve into a 3/8 "T" with a 15 PSI gauge then into my venturi tube. I am not getting any reading on my gauge, but get a little gas out the venturi. I tested the gauge and it works, I can blow into it and read about 2 psi. Is there a special regulator I need to buy, I have tried 2 different tanks and 2 different regs with the same results. any help would be appriciated. Quote
Rich Hale Posted January 30, 2012 Posted January 30, 2012 If you got a regulator for a bbq you need one that is for a forge and has a pressure adjustment and a guage on it. If that is wot you have then you need to check the size of the outlet orifice. If it is too large you will not be able to see pressure on a guage. If that orifice is too small the pressure would be high even with a low flow volume. Quote
MattBower Posted January 31, 2012 Posted January 31, 2012 Yeah, BBQ regulators won't cut it. You need an adjustable high pressure regulator. You can buy online or maybe get one from a big box store for a deep fryer. 0-30 PSI is probably more than enough for most purposes. Quote
ChrisWard Posted January 31, 2012 Author Posted January 31, 2012 I got it working, I had a high pressure reg at the house, just had to buy the adapter for the tank, I am now able to hit up to 15 psi. Ran it at 2.5 psi while I adjusted to venturi. I need to insulate the forge now and will be up and running. How much morter do I need to buy for a forge made out of a propane tank forge. I am going to have 2 inches of kaowool to make the inside area a little smaller? Quote
PJames Posted February 1, 2012 Posted February 1, 2012 I got one of those deep fryer hoses and regulators. Problem with it is no gauge. Right now I use a venturi style burner and I get good forging temps butnot welding temps. For now it is adequate to learn basic skills, but I will need to make a better burner soon. Quote
