Posted
working on designing the fuel supply for a three burner gas forge.
burners most likely will be 1/8"pipe x .035" orifice.
i know that pressure and size and temp of tank are factors,
but wondering if i need 3/8" supply side up to a cross fitting (reducing to three 1/8" outlets) or would 1/4" be big enough?
Posted
Depends on the length,,longer needs bigger. I have a three burner and a two and use about fifteen foot of quarter inch on each of them. If you purchase smaller and have to change it will be more money yoou spend.
