October 18, 201114 yr The forge is finished last month. It is my 3rd coal forge, the frame is modified from 2nd forge. It is 29 1/2" height, 24" longth and width. The fire pot is 1 1/2" depth, bottom is 5" × 5", top open is 8"× 8". The bottom is 1/2" steel plate. The air pipe is 4" and 3" in diameter. The forge works much better than those I made before. It provides bigger and stronger fire.
October 19, 201114 yr it looks great you may want to use a brick on either side to make your fire a little deeper.
October 20, 201114 yr Author Well done , I like the notches on the air gate bar , nice job all around THANKSit looks great you may want to use a brick on either side to make your fire a little deeper. Yeah, I just use 2" thickness fire brick on both side, even top as a cover for hold the fire. The top one is thinner, about 1" thickness.
