ToolSteel Posted July 15, 2011 Share Posted July 15, 2011 Firstly, thanks for the pointers on making a substitute for ITC-100. Earlier today, I bought six pounds of zircopax and five pounds of kaolin. It should be WAY more than I need. I'd like some input on ways to use this solution. I know Fiberfrax makes Moist Pak-D, which appears to be a ceramic fiber mat saturated with a coating material. This appeals to me because it would seem to be easier to put in place and extremely durable. So here's my question: What if I were to soak Durablanket 2600 in a zircon/kaolin/water slurry, then sort of "plaster" it in place? Would this have a different insulating-reflective effect than using the same material as a topcoat? On another note, I've been talking to someone who's sold ceramic insulating materials for decades and he says compressing a ceramic blanket actually makes it more effective as an insulator. Seems counter-intuitive but he seems to know what he was talking about. Any ideas? ToolSteel Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 15, 2011 Share Posted July 15, 2011 I bought 1 pound of zircopax, and have most of it left... Packing wool makes it more like a brick, which is counter productive. Take a 1 inch piece of material, and compress it to 1/2 inch. There is less gaps in the material, so it is going to conduct heat faster. The thickness is also less, so there is a steeper thermal gradient. Now, is he arguing take 2 inches and pack it into 1 inch, vs 1 inch? I don't know in that case, but 8# wool is pretty stiff and hard to compress already. 2 inches packed into 1 inch is not going to perform the as good as 2 inches fitted properly in my opinion, for the same reasons I stated for compressing 1 inch to 1/2 inch. This is my opinion, I do not have data to back this up. Now, this stuff does pack. You can take a piece of it, roll it and pack it into a crack tight as a physical barrier, such as around the burner flare for a tight fit. It works well packed like that, but it is not acting as anything other than a physical barrier in that case. Phil Quote Link to comment Share on other sites More sharing options...
