Thinus Posted May 5, 2011 Share Posted May 5, 2011 Hi I am interested in building a gas forge with easy available local material. Any plans or suggestions will be much appreciated. Thanks Thinus Quote Link to comment Share on other sites More sharing options...
ironbudd Posted May 5, 2011 Share Posted May 5, 2011 http://www.zoellerforge.com/simplegasforge.html Quote Link to comment Share on other sites More sharing options...
ianinsa Posted May 6, 2011 Share Posted May 6, 2011 Hi Thinus, One of the larger supliers of refractory cement in locally is Vereniging refractories, give them a call and they should be able to tell you who stocks their product locally. Also 3CR12 is magnetic and so you can scource it quite cheaply in local scrap yards if you can find 6-12mm off-cuts they are greal for the "doors" at the rear. Ian Quote Link to comment Share on other sites More sharing options...
Thinus Posted May 6, 2011 Author Share Posted May 6, 2011 Thanks for all the reply's. Thinus Quote Link to comment Share on other sites More sharing options...
