boilermaker8 Posted April 1, 2011 Share Posted April 1, 2011 G'day, i've been looking at a few photos on the net lately of the old style power hammers, particularly the LG and it apears the anvil is cast as two peices, (not including the dies) is the casting under the main anvil block (where the die is wedged in place) is that part hollow or solid cast? it's hard to tell, however i'm just interested as to the construction of these machines as i am looking to build myself a power hammer and am exploring options as to construction methods? thanx in advance for your replies ;) Quote Link to comment Share on other sites More sharing options...
macbruce Posted April 1, 2011 Share Posted April 1, 2011 The casting that holds the lower die is called the ''sow block'', and is solid........Don't rule out building an air hammer...good luck! Quote Link to comment Share on other sites More sharing options...
peacock Posted April 1, 2011 Share Posted April 1, 2011 The casting that holds the lower die is called the ''sow block'', and is solid........Don't rule out building an air hammer...good luck! The early sow blocks were solid. The later (new style) are hollow. It's easy to tell the hollow ones as they have a hole thru them from front to back. I think Little Giant now offers a solid replacement for some sizes. The early one piece frames without sow blocks are also hollow in the anvil area. Quote Link to comment Share on other sites More sharing options...
fciron Posted April 1, 2011 Share Posted April 1, 2011 I've got a new style 25 lb. Little Giant. Both the sow block and the cone-shaped part of the frame it sits on are hollow. Quote Link to comment Share on other sites More sharing options...
Bob S Posted April 1, 2011 Share Posted April 1, 2011 I've got a new style 25 lb. Little Giant. Both the sow block and the cone-shaped part of the frame it sits on are hollow. tru dat. Bob Quote Link to comment Share on other sites More sharing options...
