joshua.M Posted February 27, 2011 Share Posted February 27, 2011 so i have a canedy otto/ western cheif blower, it was great when i got it, but in the past week it has been making a poping/gringing noise and not putting out as much air, i went to clean the oil out, the tube was clogged, i got it unclogged and the oil was abnormaly nasty (i change every 3 weeks) and i chased it with kerosein to get it clean, then put new oil, it was still poping and grinding, so i took off the gear plate and didnt see anything wrong, so i put it back on and oiled again, and now it wont turn at all. I'm worryed that i wont be able to fix it thanks in advance -Josh Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted February 28, 2011 Share Posted February 28, 2011 Josh, did you check to see if the blades are all still intact? Could be that some blades came loose. You change oil in the blower every 3 weeks? WOW!! Quote Link to comment Share on other sites More sharing options...
ironstein Posted February 28, 2011 Share Posted February 28, 2011 Josh, alot of times the casing for the fan blades gets stuff in it, or had some sort of stuff in it. i have seen them with wasp nests, mouse nests etc. Could also be the gears. I got my canedy otto blower off ebay, i took it apart to clean it and some of the gears were very well used, after some bushings and adjustments, it works great, but only in one direction, if i rotate it the other way it grinds a bit. Quote Link to comment Share on other sites More sharing options...
Luke March Posted March 7, 2011 Share Posted March 7, 2011 Josh - Unless the gears are really messed up, you should be able to fix it. In the solid fuel forges section, there's a thread I posted about a Canedy-otto I fixed up. I had to replace all the bearings, and one gear - but it was really easier than I thought it would be. Most of the work was just getting all the old grime out. Checking the fan is also a very good idea; there could be something in there, or perhaps the fan is making contact with the blower shell. Quote Link to comment Share on other sites More sharing options...
joshua.M Posted March 7, 2011 Author Share Posted March 7, 2011 Josh - Unless the gears are really messed up, you should be able to fix it. In the solid fuel forges section, there's a thread I posted about a Canedy-otto I fixed up. I had to replace all the bearings, and one gear - but it was really easier than I thought it would be. Most of the work was just getting all the old grime out. Checking the fan is also a very good idea; there could be something in there, or perhaps the fan is making contact with the blower shell. Update on the blower i got it all taken apart and cleaned and there is what looks to be an Al cog gear that is almost completly stripped so i called the guy i got it from he thinks he may have a spare part so as i'm waiting for the part it is sitting in deisle fuel to clen all the old grime out of it -josh Quote Link to comment Share on other sites More sharing options...
