HWHII Posted February 16, 2011 Share Posted February 16, 2011 Thought I would share this new forge I just built with the new Diablo Burner from Chile Forge. I have not got to play with it much. I have heated 1 1/2" solid to bright orange and 1/2" solid to yellow at 10 psi working line pressure. I like it alot seems to be a great burner. Quote Link to comment Share on other sites More sharing options...
Chris X Posted February 17, 2011 Share Posted February 17, 2011 what do you think of it so far compared to what you had? 10psi...i wonder if thats normal for that particular burner or atmo forges. Quote Link to comment Share on other sites More sharing options...
HWHII Posted February 17, 2011 Author Share Posted February 17, 2011 what do you think of it so far compared to what you had? 10psi...i wonder if thats normal for that particular burner or atmo forges. Cris X , I gave it a good work out yesterday. It is much more efficient than my other forges. This burner is recomended to run from 5psi to 15 psi and is works well at high alltitudes. In my other forges I would run 20psi to 25psi with either two or three burners to get the same results. Propane here is $2.25 a gal. for 10 or more gal. $2.49 if you buy less. I think I will see some savings over the year. Quote Link to comment Share on other sites More sharing options...
