monstermetal Posted October 23, 2010 Share Posted October 23, 2010 Hofi Punch lube recipe Does anyone know the ratio of moly to graphite in Hofi's lube recipe? Pretty much I know its dish soap moly and graphite... just need to know the ratio.. Thanks Quote Link to comment Share on other sites More sharing options...
Grafvitnir Posted October 23, 2010 Share Posted October 23, 2010 I´ll make a copy/Paste of the original BP1023 "Take two soup spoons of each powder, graphite and Moly, and mix together in a container. Add liquid soap and mix until it forms a paste. Transfer this paste to a larger container that will be used to dip and cool the tool. Add water to make 1 pint of solution. Mix well. To use the lube, just dip the tool into the solution. You may want to stir the solution occationally if it starts to settle out. The solution can be brushed on the tool if that is more convient. Place a lid on the container for storage. The 4 spoons of powder is enough to make a pint mix of lube solution and will last for a long time." Hope it helps, Rubén Quote Link to comment Share on other sites More sharing options...
Coolhandluke Posted October 24, 2010 Share Posted October 24, 2010 What is exactly and where would I obtain some "Moly" ? Quote Link to comment Share on other sites More sharing options...
Dodge Posted October 24, 2010 Share Posted October 24, 2010 What is exactly and where would I obtain some "Moly" ? Moly = Molybdenum. A Google search for Molybdenum Powder Quote Link to comment Share on other sites More sharing options...
monstermetal Posted October 24, 2010 Author Share Posted October 24, 2010 Thanks Ruben! thats what I needed! Quote Link to comment Share on other sites More sharing options...
jimbob Posted October 24, 2010 Share Posted October 24, 2010 What is exactly and where would I obtain some "Moly" ? you can buy a can from Midway USA they sell reloading supplies and use it to coat bullets here is a link http://www.midwayusa.com/viewproduct/?productnumber=183655 another http://www.midwayusa.com/viewproduct/?productnumber=466679 Quote Link to comment Share on other sites More sharing options...
Sam Thompson Posted October 24, 2010 Share Posted October 24, 2010 You need Molybdenum disulphide (MoS2). Quote Link to comment Share on other sites More sharing options...
