ledson Posted March 13, 2010 Share Posted March 13, 2010 I had bought this piece at a metal yard with hopes that I might be able to use it as a forge, attached are some picture and the dimensions are as follows... 19in deep 6in in dia The two fittings going into the side of it are a little more than an inch in diameter on the inside. Now I'm not sure what exactly the liner inside the stainless outer piece is made out of, there is some packing between the inner and outer shell too. I think maybe it was used for steam at one time in some sort of factory. Quote Link to comment Share on other sites More sharing options...
