mite5255 Posted January 8, 2010 Share Posted January 8, 2010 hi....does any one know were i can get a new leather piston cup (more then likely wrong name but its the leather cup thats inside the blow torch ) for a blow torch like the one in the photo thanks regards mike Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted January 8, 2010 Share Posted January 8, 2010 I don't know about the leather piston cup for that torch. But Coleman type lanterns use a similar pump up piston type set up and I have made my own replacements for them. Oil the leather down so that it will seal and you're in business. Hope this helps. Good luck. :) Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 8, 2010 Share Posted January 8, 2010 Old skool there. If you make your own leather cut it oversized and soak in oil before fitting. Removing extra is no challenge. I have had good success with soaking the old leather if it wasn't damaged, but they tend to develop a tear on one side for some reason. Search petromax lanterns on ebay, there are always a few leathers on there, dunno if the right size though. Phil Quote Link to comment Share on other sites More sharing options...
mite5255 Posted January 8, 2010 Author Share Posted January 8, 2010 thanks for the reply s....i should have remembered about making my own.....as i get older my memory just gets worse regards mike Quote Link to comment Share on other sites More sharing options...
