jmeineke Posted October 29, 2009 Share Posted October 29, 2009 (edited) I'm having a tough time getting a 1:12 taper on a 3" section of 1" pipe. Right now, I have minimal equipment - a MAPP gas torch, a hammer, an anvil and some Iron rod that I tried using to fuller the end. About the best I've been able to do is about 1/2 of an inch - just enough flare to make the burner work. Here's what it looks like: And here's the flame that it produces: I don't think the flame is too bad, but it is rounded and not pointy like images of other flames that I've seen from the 3" 1:12 taper. Do you think that this is good enough for a forge, or should I maybe weld up a jig to form a better nozzle? I've thought about welding some properly tapered 1/4" sections of bar stock to a rod and use that to fuller the end (like an arrow head, but with 4 sides). Don't know if that would work or not either. Any help / advice would be appreciated. Edited October 29, 2009 by wrkn4alivn Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 29, 2009 Share Posted October 29, 2009 I was using a union on the end of my burner at first. That was just a step edge. I used it in my forge body a few times that way too. Your flame looks good. Stick it in the forge and it won't need a flare unless you are running at very low pressures, but your forge won't be glowing then. A poor flare shape can contribute to "huffing" but so can other things like wind. If you use a burner enough the flare will deteriorate and need replaced. I bought stainless flares from Zoeller, and have since been told those last much longer, but also eventually deteriorate in the same way. Use it, make a new flare later. Phil Quote Link to comment Share on other sites More sharing options...
jmeineke Posted October 29, 2009 Author Share Posted October 29, 2009 Thanks - I appreciate it. Quote Link to comment Share on other sites More sharing options...
